Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Rectangular MCHES modelling › Reply To: Rectangular MCHES modelling
Just a note on scale. Do NOT build the channel in real scale: CAD kernel tolerances tend to merge micron scale parts into a corrupted mess. Scale up and then rescale in Fluent when you import the mesh. A 2mm channel should be fine, 20microns will almost certainly not be.
