Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › DYNAMIC EXPLICIT SOLVER STOPPED WITHOUT ANY ERROR › Reply To: DYNAMIC EXPLICIT SOLVER STOPPED WITHOUT ANY ERROR
January 24, 2024 at 5:05 pm
Chris Quan
Are you able to view the results? If yes, look at the admodel.log file to see if there are any error messages.
Were you running it as "Distributed" solve? If yes, how many cores were used? Student version has a limitation on maximum number of nodes/elements. If the model size is small, there is no need to use many cores. If you run the model without "Distributed" solve or using a small number of cores like 2 or 4, will model run to finish?
