Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Squeezing two rubbers and water › Reply To: Squeezing two rubbers and water
javat33489
In real life, these rubbers will be submerged in water. That is, these rubbers are mounted on a pipe, and this structure is located in an even larger pipe, which will be filled with water. I need to understand when compressed whether the water will remain between the rubbers or whether it will be squeezed out completely.
