Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ACP pre to static structural solid composite transfer not working › Reply To: ACP pre to static structural solid composite transfer not working
January 24, 2024 at 2:47 pm
You cannot switch between solid and shell composite model after you have connected the ACP-Pre Set up with Static structural Model
Can you delete the static structural and create a new one. Try to send the solid composite and see if it works. If it doesnt work, can you post the error messages
