Ansys Learning Forum Forums Discuss Simulation 3D Design Bad faces Reply To: Bad faces
Devendra Badgujar
Hello Rana,
You might have to delete the surface and recreate it using tools like pull, fill etc. If delecting that surface converts your solid to surface you can use Solidify tools from Repair Tabs to see if that helps.
DevendraÂ
