Ansys Learning Forum › Forums › Discuss Simulation › Fluids › AQWA LINE: wrong angle of the principle axes of the cut water plane area › Reply To: AQWA LINE: wrong angle of the principle axes of the cut water plane area
January 24, 2024 at 12:57 pm
Hi, thank you for your answer. How did you calculate the GMx and GMy without the use of the principal second moments of area of the water plane?Â
