Ansys Learning Forum Forums Discuss Simulation General Mechanical Retaining only converged data in an unconverged solution Reply To: Retaining only converged data in an unconverged solution
Lydia Lymperopoulou
The reason why the cells are not automatically filled is because your analysis is not converged. And the software cannot know that the local maximum already computed is the total maximum of the converged analysis.
I believe you should try and solve your convergence problem first.
