Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Particles didn’t show up when using the DPM volume injection › Reply To: Particles didn’t show up when using the DPM volume injection
January 24, 2024 at 9:45 am
If you open the Particle Track panel, then change the size/display option can you see them? At 2.5microns the particles will follow the flow, and are also very small so may not be easily seen.Â
