Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Stall Angle!!! › Reply To: Stall Angle!!!
January 24, 2024 at 9:26 am
Have a look at the NACA tutorials. A good starting point to figuring out what to do with the CFD model is consider how you'd do this experimentally: ie what defines stall? What data do you then need to determine if stall has occurred. Then see how you can do that in the software.Â
