Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with mesh on rubber in static analysis › Reply To: Problem with mesh on rubber in static analysis
January 12, 2024 at 12:18 am
Transient can be helpful in models with an instability where the structure approaches a shape with no static equilibrium, but there is a new static equilibrium on the other side of the instability. It doesn't seem like that is the issue in your model. You can certainly try a Transient solution.
