Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Inhouse post-processor can’t read .rst file from 2021R2 version › Reply To: Inhouse post-processor can’t read .rst file from 2021R2 version
January 11, 2024 at 10:31 pm
mjmiddle
It was changed so that the result file is compressed by default using the /FCOMP command. See the /FCOMP documentation:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_cmd/Hlp_C_FCOMP_sl.html
Especially the link about third party tools:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_prog/Hlp_P_INT2_1.html
If you use workbench Mechanical, there is a setting in the Analysis Settings to turn off result compression:
