Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Need help to create a circle on a curved surface › Reply To: Need help to create a circle on a curved surface
January 11, 2024 at 4:48 pm
mmia1
HiÂ
Thank you for the reply. The thing is that I have to do a parametric study so I wrote a matlab code that prepares k files. I have a complex geometry of storage fuel tank and pipes together so I thought matlab code to prepare k files would be good for me.
So, is there no option or way available in LSDyna to do the exact operation you showed herein on the mesh part I mean the k file I imported in LSDyna (Fig. below)? If no then I think I have to do this in LSDyna instead of importing k files which will be time consuming.Â
Thanks again.
