Ansys Learning Forum Forums Discuss Simulation Fluids Help post! FLUENT—ROCKY coupling calculation errors! Reply To: Help post! FLUENT—ROCKY coupling calculation errors!
OK, I do suggest not using Workbench. Open Rocky from the Start menu. In Rocky's geometry you should see Fluent's boundaries, delete all interior surfaces and (in this case) the outlet. We are adding a Rocky course to the AIS (Learning) system, so it will be easier to learn shortly.
