Ansys Learning Forum › Forums › Discuss Simulation › Electronics › SIwave ODB++ import problem from Altium › Reply To: SIwave ODB++ import problem from Altium
Mario Di Marino
Hi Dan,
Thanks again for your time, I will try to contact Altium as well to see if they have any suggestions.
As for the IPC format, I tried it and I saw that it doesn't cause any problems except for some names in which it inserts spaces or other characters that don't allow you to launch the simulations but with a little patience I think I can overcome this problem.
Thanks again for everything, if you have any other ideas they are welcome.
Thanks and regards, Mario.
