Ansys Learning Forum Forums Discuss Simulation Photonics Common Mode Rejection Ratio Reply To: Common Mode Rejection Ratio
Afroditi Petropoulou
Dear Minu,
If you are using ports, you can use either the square value of S or the T_out result from the mode expansion result of the port for each mode.
Best Regards,
Afroditi
