Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How to find out Phase shift of transmitted wave varying radius vs wavelength › Reply To: How to find out Phase shift of transmitted wave varying radius vs wavelength
January 11, 2024 at 9:47 am
Dear Nayem,
What you plot is the phase. The paper plots the phase shift. As you can see, the calculated phase has a range between -3.14 and 3.14, while the phase shift plotted in the paper has a range between 0 and 2. Is there a refernce phase discussed in the papaer? What does a phase shift means in the paper you mention?
If there is a reference phase then you need to subtract it from the one you caclulated.
Best Regards,
Afroditi
