Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Error when running a topology optimization on a cluster (Linux) › Reply To: Error when running a topology optimization on a cluster (Linux)
January 11, 2024 at 1:58 am
Lito
Hi samupekkaojanen,
Based on the information provided, you are running the scripts without GUI on Linux.
>>>Running CAD jobs on headless Linux systems – Ansys OpticsÂ
If you are able to run:Â
xvfb-run "/home/opt/Lumerical/2021-r1/python-3.6.8rc1/bin/python" somepythonscript.py
But you are having issues running a different lumapi/lumopt script:
xvfb-run "/home/opt/Lumerical/2021-r1/python-3.6.8rc1/bin/python" topology_runsim.py
Then the issue is with your script, "topology_runsim.py".
Try to saving the script below (lumtest.py):Â
## save as lumtest.py ##
import lumapi
fdtd = lumapi.FDTD()
fdtd.addfdtd()
fdtd.addring()
fdtd.addmesh()
fdtd.save("lumtestpy.fsp")
Run the above script:Â
xvfb-run "/home/opt/Lumerical/2021-r1/python-3.6.8rc1/bin/python" /path_to_script/lumtest.py
It should create the "lumtestpy.fsp" simulation file on the same working directory as script.Â
