Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Update PCB layout in SIwave › Reply To: Update PCB layout in SIwave
January 10, 2024 at 6:35 pm
Import the new board file in a New SIwave project. Next please go to the export tab in the old project and export a Component File. You can now import this file into the new project by going to the import tab. IF the components just move and you are still using the Same part number and Reference Designator your port setup pingroups and other things will be transfered to the new project.Â
