Ansys Learning Forum Forums Discuss Simulation Photonics set up the simulation region Reply To: set up the simulation region
Niki Papachristou
Hi Ceshi,
Thank you for reaching out to us! I believe that the reason is to reduce the time and storage consumption. Since in the metameterial surfaces simulation we focus on the phase results and these are not affected from the simulation region, then going for your first case should be enough.
Kind Regards,
Niki
