Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › ansys2022r1 parallel solution error › Reply To: ansys2022r1 parallel solution error
guy.wiener
I have this issue as well, using R14.1.
I create a map file (not with boundary_ale_mapping) and tried changing the precision with no effect on the error.
I have found a workaround:
When writing the map file, have "map=mapfile map1=mapfile1".
Then when reading the map file, also place "map=mapfile map1=mapfile1" in the command.
I have seen this circumvent this apparent bug.
