Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Temperature setting in Ansys workbench transient thermal › Reply To: Temperature setting in Ansys workbench transient thermal
Hi
Yes, Your setting for adding the initial temperature seems correct. Are you getting any discrepancies in the result using this method?
For the Steady-State and Transient Thermal analyses, use the Details of the Initial Temperature object to scope the initial temperature value. For a Transient Thermal analysis that has a non-uniform temperature, you need to define an associated Initial Temperature Environment.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/mech_obj/ds_initial_temp_o_r.html?q=initial%20temperature
Best Regards,
Sampat
