Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys Mechanical crashes › Reply To: Ansys Mechanical crashes
"I have a very similar problem. Have you already found a solution? In my case, the error does not occur during the display of results but rather during the representation of the distribution of hydrodynamic pressure (/forum/forums/topic/mechanical-crash-after-hydrodynamic-pressure-mapping/). So, it's a very similar issue. My system is also a laptop and has two GPUs: an integrated Intel graphics card (iGPU) and a dedicated Nvidia RTX 2000 (dGPU). I have found that the error does not occur when I deactivate the iGPU or work on a external display (while the internal display is disabled). However, since both options are not optimal for my workflow, I would like to avoid this. I have already tried assigning Ansys Workbench exclusively to the dGPU in the Nvidia Control Panel and Windows graphics settings, but unfortunately, the error persists. If anyone has resolved the issue or has other suggestions, I would be very grateful.
