Ansys Learning Forum › Forums › Discuss Simulation › Fluids › particle size distribution in histogram is not continuous › Reply To: particle size distribution in histogram is not continuous
Sorry for replying late due to the maintenance of this forum.
there is a bluff body in this combustor. I believe the effect range will be confined to the upstream section.
I extracted the particle number data in one figure.
in the very beginning, x = 1 mm, the particle size distribution does not look like the Rosin-Rammler distribution.
in the very end x =1.95 m, the particle size is uniformly distributed under 70 microns.
you can also see there is no particles with 40 micron.
the total number of particle (parcel) also changes.
I sampling this for certain time, the dpm file reaches up to 400 Mb. I am not sure where sampling time is enough.
