Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › SpaceClaim gives me a “not responding error” after trying to share topology. › Reply To: SpaceClaim gives me a “not responding error” after trying to share topology.
Keyur Kanade
Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
If you have multiple components please make only few components visible and then use Share. It works on only visible bodies. This way you can find which body is giving issue.
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
