Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Autodyn subroutine issue – ideal gas EOS › Reply To: Autodyn subroutine issue – ideal gas EOS
January 9, 2024 at 2:38 am
Thanks for you kind response!
As you mentioned, "variable gamma" is defined in "Module EOS_USER_1" just like the picture below(variable "rho" also!).
I changed the array size to "Dimension 1" just like your comment.
However, after I changed the array size of "variable gamma" to 1, the same error has occurred.
Why has the error occurred? I still have no idea about it.
