HDLI
Hello Ganesh,
      1). Could you try to run the themal model individually? to see if the model has any issues. It looks like you are using the themal or customer FMU.
      2). Could you check the fixed-step size, stop time in Matlab configuraiton parameters? we could not run zero step.
       3). From the error message, it seems numbe of points might be 0 in MotorCAD model’s calculation tab > transient. Could you check if a FMU input is zero for numbe of points?
       The FMU would support the modules and MotorCAD FMU that the tutorial mentioned. It seems we do not need to run “shareMATLABForFMUCoSim” commmand.
HDLI
