Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Antenna Received Power › Reply To: Antenna Received Power
January 8, 2024 at 3:20 pm
If you are interested in the received power, an antenna can be simulated with both: port and plane wave. And then, with the PW excitation activated, use the field calculator to analyze the voltage or power in the port area, depending on the port type and feeding configuration
