Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About Voltage curve in my battery simulation › Reply To: About Voltage curve in my battery simulation
The issue you're experiencing might be related to the experimental discharge period being too short, resulting in insufficient data to fit the curves. This could be due to a unit problem or an insufficient number of experimental data points. To have a meaningful discharge curve, the time period should cover a good portion of the Depth of Discharge (DOD) range. A good rule of thumb is to cover at least 80% of the depth of discharge curve at each charge rate (C-rate). If the battery is assumed to discharge to DOD=0.2, for instance, the sample period for C-rate=0.1 should be 0.8*3600/0.1 seconds, and for C-rate=1, it should be 0.8*3600 seconds. Note that the unit of time in the tool is always in seconds, so all discharge data should obey this convention. What do your curves look like?
