Ansys Learning Forum Forums Discuss Simulation Fluids Solidification of a gel (fluid) by the spray of liquid nitrogen. Reply To: Solidification of a gel (fluid) by the spray of liquid nitrogen.
Please can you post some images?  Also, check the phase material in the region you're seeing the solid. Depending on convergence you may have a tiny volume fraction of the gel in the gas region that's causing some confusion when post processing.
