Ansys Learning Forum Forums Discuss Simulation Electronics Core Loss for Parametric Setup Reply To: Core Loss for Parametric Setup
Timos
Hello, Please check the Material Properties: make sure that the material properties, especially the electrical steel loss model parameters, are correctly assigned to the iron material of the coil. Verify that you've entered the correct values for the parameters. Also confirm that you've set up the excitation currents correctly. You can check if the current density and the magnetic flux plots are plausible. Ensure that the frequency range covers the expected operating range of your system.Last but not least, check the post-processing plots to ensure that you are looking at the right result plot for core losses.
