Ansys Learning Forum Forums Discuss Simulation Photonics How to improve the response speed of FDTD graphical interface Reply To: How to improve the response speed of FDTD graphical interface
Dimitris Polyzos
Hello Coulson,
Thanks for contacting us. I can understand your issue but this is something expected when you want to simulate large scale objects, such as your metasurface model. As you mention, the millimeter scale is quite large to simulate it, and it  will definitely need a large CPU capacity to run. I would suggest to decrease the mesh, but for a large scale model that would affect the accuracy of your results. Also, to decrease the simulation capacity and time you can take advantage of the period/symmetric BCs options. Some metamaterials-metasurface application examples can be found in the following link, where you can pump some ideas:
https://optics.ansys.com/hc/en-us/articles/360043683273
On the other hand, if there is a need to simulate a millimeter scale then you can use the multiple High performance Computing resources. More information in the following links:
HPC
Concurrent-computing
Distributed-computing
I hope I helped. Kind regards
Dimitris
