Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Need help regarding metasurfaces/metalens (transmittance intensity) › Reply To: Need help regarding metasurfaces/metalens (transmittance intensity)
Taylor Robertson
I cant actually see the error, but likely an issue with sweep or subsweep set-up. You can actually set the wavelength and frequency point in the RCWA object though this is the easiest. Then just use the sweep to cover the required geometric parameters.
