Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Discrepancy between creep strain – ANSYS vs creep Model – Simple rod in tension › Reply To: Discrepancy between creep strain – ANSYS vs creep Model – Simple rod in tension
January 5, 2024 at 7:15 pm
It is the same code, so if the two inputs are identical, the results should match. The only way to find what is different is to put the two ds.dat files side by side and do an apples-to-apples, line-by-line comparison of the all input specifications to identify what is different.
