Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Characteristic mode analysis: how to plot antenna surface current for each mode? › Reply To: Characteristic mode analysis: how to plot antenna surface current for each mode?
Praneeth
Thank you for reaching out to the Ansys learning forum.
It is possible to plot the fields for all the analyzed modes using the Characteristic mode solution type.
Please modify the magnitude of the modes available under Excitations>Edit Source to excite the specific mode for viewing the fields.
Best regards,
Praneeth.
