Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Phase response vs. wavelength › Reply To: Phase response vs. wavelength
Dimitris Polyzos
Yes you are correct, the angle of operation is referred to the phase. You can use imple script commands as you would extract the electric field or other results from the script workspace. More information can be found in this link :
Introduction-to-Lumerical-datasets
Regards
Dimitris
