Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Stress Analysis at 200 Hz › Reply To: Stress Analysis at 200 Hz
January 5, 2024 at 10:18 am
Erik Kostson
Hi
This could be a resonance (e.g., axial mode) excited as you move the part very fast back to zero – not sure why you do not see it so much at 100 Hz.
If you do not care about such dynamic effects (e.g., resonance), then run quasi-static by setting time integtaion to OFF (this can be done under analysis settings).
What are you trying to model/analyse here? So describe the goal of your analysis, and what results do you want to study?
All the best
Erik
