Ansys Learning Forum Forums Discuss Simulation Fluids Multiphase flow – Free surface jet deviation to analytic solution Reply To: Multiphase flow – Free surface jet deviation to analytic solution
christian.scheffler
Now the free surface jet and the analytic solution is more or less equal. The model needed the following changes compared to the above settings:
  • use openings for left and right wall instead of wall left and outlet/wall right
  • setting a physical timescale of 0.05
This improved significantly the convergence.
Neither one of the settings alone did the trick.
The timescale value (time step) is just a guess, I didn’t calculated it based on the Solver Theory Guide. But it is certainly a better option to calc it according to 1.273, 1.274, 1.275 (2023R1). Just to mention it here: the jet velocity is 4m/s, the dimension of the jet in x about 1m, the cell size 1.5mm x 1.5 mm x 1.0 mm. The jet width is resolved by about 10 cells.
Comparison free surface jet to analytical solution
Convergence
