Ansys Learning Forum Forums Discuss Simulation Fluids particle size distribution in histogram is not continuous Reply To: particle size distribution in histogram is not continuous
And what models are on? If you replot with “Percent” deselected what do you see?
Also check the RR definition in the manual is what you're expecting. I tend to use 5-10 single size injections over RR as it's also then easier to work out what particles go where. Ie if a large particle mass is seen in a report is it few big particles or many smaller ones - with RR you'll need to interrogate the DPM.out files.
