Ansys Learning Forum › Forums › Discuss Simulation › Fluids › particle size distribution in histogram is not continuous › Reply To: particle size distribution in histogram is not continuous
ll00023
This is the figure I use mass weighing.
I set the RR distribution by 10 groups of particle. I think this is the reason.
But I don't understand the weighing meaning. how the weighing factor works?
the other question is: why the particle size on this sampling is different from the the figure of particle tracks?
from histogram, the mass of particle concentrates on about 150 micron. but base on RR distribution setting (mean diameter 65 micron,), it should be concentrating on much smaller size.
the mass fraction of particle based on sizes are posted.
Thank you.
