Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Creating an Air Area › Reply To: Creating an Air Area
December 7, 2023 at 7:06 am
Thanks for the reply.
Currently, I would like to simulate free-falling objects on a sand model using DEM in the air region of ALE.
I look at reference materials and set it up, but the time required for analysis is enormous.
Is it possible to use DEM and ALE together?
I will attach the Keyword with which I set ALE as an image. I'm using *EOS_LINEAR_POLYNOMIAL , is this a mistake?
Also, do you think that the LS-PrePost space is a space where nothing exists, not even a vacuum?
