Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Spray deposition on the tank wall by using DPM model and solid cone injecton. › Reply To: Spray deposition on the tank wall by using DPM model and solid cone injecton.
rehmanm
Thanks for your reply. Actually, in my case, the outer wall is just a metallic tank stationary smooth wall. I want to see the sticking of the spray particles to the wall. In this case, still you will recommend of using the Eulerian wall film (EWF) model? Kindly guide me in this. thanks.
