Ansys Learning Forum Forums Discuss Simulation Electronics Issue with differential port solution in HFSS Reply To: Issue with differential port solution in HFSS
Faezeh Tork Ladani
Hi!
Try Driven Modal Solution Type. The two modes you define for the port there will be similar to differential and common modes in Driven Terminal. In the Waveport definition, post processing Tab, you can renormalize specific modes to your desired impedance(complex and frequency dependent as well) with the format of resistance+1i*reactance
