Ansys Learning Forum Forums Discuss Simulation Photonics After using the script to build the model, the parameter scanning is used to rep Reply To: After using the script to build the model, the parameter scanning is used to rep
Dimitris Polyzos
Hello ,
Could you please share the script with which you build your model, to have a look myself and give you proper guidance on what is going on?
I reckon that something is wrong with the parameter sweep. However, I cannot be sure without checking the file first.
Kind regards
Dimitris
