Ansys Learning Forum Forums Discuss Simulation General Mechanical How to ensure that Tip of Force Vector stays at specific location? Reply To: How to ensure that Tip of Force Vector stays at specific location?
armin.abedini
Hi Dennis,
You indicated that the location of load application is at a specific point. How is the evolving direction of the load specified? Is it normal to a particular surface? If so, you can apply pressure instead of force and it always remains normal to the force no matter how the structure is deformed.
As a side note, remember to turn on "Large Deflection" under Analysis Settings to account for nonlinearities arising from large deflection.
