Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Is there the error in this simulation? › Reply To: Is there the error in this simulation?
December 6, 2023 at 1:07 pm
Dear Sangmyeong,
What are the materials that you are using for the two objects and what are their dimensions (of the rectangular, cylinder and FDTD region)?
As I can see you run a sweep over the period, is that correct? Is it for both x and y axis span?
Did you check the material fitting in the material explorer to see if it is ok for the whole bandwidth (300nm-1000nm)?
Thank you in advance.
Best Regards,
Afroditi
