Ansys Learning Forum › Forums › Discuss Simulation › Fluids › BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES › Reply To: BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
December 6, 2023 at 12:00 pm
Hello, many error files were generated after an error occurred。Other files contain the following information: Abnormal Exit! How to solve?Even if I turn it back on, it's still a repetitive error that can't be calculated.The content of flunt-0-error is as follows:
Node 0 Fatal signal raised sig = Segmentation fault
 30d93010 CX_Primitive_Error
 90e20cc0 seh_filter_exe
 30e35a20 logical_right_shift
 7217eb20 _C_specific_handler
 93572290 _chkstk
 93521030 RtlRaiseException
 93570e90 KiUserExceptionDispatcher
 2e27d930 Dump_Dataship_new
 2e2601d0 Build_Grid
 2e2601d0 Build_Grid
 2ded2050 start_cancel_box
 30e20250 eval
 2dfe7e50 PRF_Command_Start
 2dfea570 PRF_Node_repl
 2dff5fc0 Delay_Error
 92c07330 BaseThreadInitThunk
 93522690 RtlUserThreadStart
Error [node 0] [time 12/5/23 21:44:1] Abnormal Exit!
 93572290 _chkstk
 2e2601d0 Build_Grid
 2e2601d0 Build_Grid
 30e20250 eval
 8e677b80 CX_Primitive_Error
 8e71abb0 logical_right_shift
 93572290 _chkstk
 8be1b570 Dump_Dataship_new
 8be02460 Build_Grid
 8be02460 Build_Grid
 8bb42130 Get_Network_Nb
 8e706080 eval
 8bc687a0 PRF_Command_Start
 8bc6afc0 PRF_Node_repl
 8bc6b890 init_rsubrs
Error [node 0] [time 12/5/23 21:48:28] Abnormal Exit!
 93572290 _chkstk
 8be02460 Build_Grid
 8be02460 Build_Grid
 8e706080 eval
Error [node 0] [time 12/5/23 21:50:29] Abnormal Exit!
 93572290 _chkstk
 2e2601d0 Build_Grid
 2e2601d0 Build_Grid
 30e20250 eval
Error [node 0] [time 12/5/23 21:53:30] Abnormal Exit!
 93572290 _chkstk
 2e2601d0 Build_Grid
 2e2601d0 Build_Grid
 30e20250 eval
Error [node 0] [time 12/6/23 17:53:4] Abnormal Exit!
