Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Discovery run time › Reply To: Discovery run time
jwkim23
First of all, thank you for being able to get information about run time using the method you mentioned. However, in the picture above, a log file is created when the livegx solver is used, but a log file is not created when the livegx solver is not used. So how do I check the run time when the livegx solver is not used?
