Ansys Learning Forum Forums Discuss Simulation Preprocessing Inflation cut off due to divided components Reply To: Inflation cut off due to divided components
Keyur Kanade
That cylinder is very close to the wall. You will need to use very very fine surface mesh size in that proximity. Once you get very fine size on the surface mesh then you may get few layers in that proximity area. With the corase surface mesh in that gap you will not get inflation layers.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
