Ansys Learning Forum › Forums › Discuss Simulation › Electronics › HFSS Port vs SMA Connector in Design – Provide wrong S11, Why? › Reply To: HFSS Port vs SMA Connector in Design – Provide wrong S11, Why?
December 6, 2023 at 5:29 am
Hi Imtiaz,
It looks like there is an issue with the model. It looks like the signal is completely reflected back to the port. Please check the following in your model with the connector:Â
- Did you make sure that the connector outer conductor is only touching the ground planes?
- Did you make sure that the connector inner conductor is only touching the signal trace?
- Did you verify the port excitation on the SMA connector?
- Is there an explicit air region or how did you model the surrounding region?
- Are the dimensions for the SMA connector correct?
Best regards,
Praneeth.
