Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluid-solid-fluid Interfaces › Reply To: Fluid-solid-fluid Interfaces
December 5, 2023 at 2:23 pm
Be careful with the words you use - we need to be very careful with definitions to avoid confusion.Â
A coupled wall (wall & wall shadow) will pass heat. An interface pair with wall settings will also pass heat. Look very carefully at the temperature near the wall; do you have enough mesh to pick up the boundary layer and are you looking at a sensible temperature scale?
